Custom Sprocket Adapter
GAS+RIDEZ
Need help with my Pirate Cycles Custom Sprocket Adapter, I have 44 teeth and I want to install a 40, Pirate do not have available,the question is will it work with Manic Mechanic Sprocket will someone has it and has made the change?Thank's
I did it for the manic adapter, got a standard 9 hole 40 tooth sprocket, centered it and drilled the bolt holes. if you measure carefully you can get it almost perfect.
good luck,
fatdaddy.
I still prefer making my own from a STEEL sprocket. IF you don't get the alighnment PERFECT on an aluminum sprocket it wears out FAST. PERFECT is kinda hard to do.but not impossible.
