Scott.D.Lang
the new ones he has comeing in are 40mm long I believe not the 38mm
haaha nice, the only thing im not looking forward to is the amount of time i had into my current cylinder grinding ports and adding ports to get where im at. Im going to buy a new cylinder this way ill have a whole complete engine just about, besides the head and reed cage. If this all works ill be able to turn even higher rpm than i am now and not wear the cylinder out no where near as fast as the stock piston and rings.
i used a carbide double cutter sphere bit 6$ ea. on ebay and removes materiel in a hurry! I also bought a set assortment of dremel high speed cutters on ebay for like $15 there small and can get in the tight places with no problem, keep in mind the highspeed cutters need a smaller chuck in your dremel than the double cutters.
All together took me a couple hrs taking my sweet time.
How did you measure the degrees? i advanced the exhaust a little, but would be interesting to know what degrees.
