Took the new engine for a 16.5 mile ride yesterday, on the last of it I stopped for a couple minutes and noticed when I rev the engine I'm hearing a high pitched whistle sound when I jack the throttle, it's definitely the sound of air squeaking past a small opening somewhere, exhaust gasket looks good and I know carb gasket is sealed, pretty sure it's got to be the head gasket, I also noticed that the top of my spark plug is turning a blueish color so I will have to pull the carb and drill the jet up a size for sure also, I think at a cruise speed of about 32-34mph mix is not to far off, but when I hammer it and run it up over 40mph and keep it at the current top speed of 42mph it's a bit lean and gettingf very hot as well, gonna guess overheating is what has got my head gasket and possible warped the head a bit, no big thing, gonna pull that head resurface it and put aside for another engine, I'll just put the Puch head on and rejet the carb up a bit and that should solve my probelms.
The carb was tuned perfectly on the engine it came off of but it doesn't have nearly the port work that this one does so this tells me that my porting has really helped it flow better because of the lean condition I'm now having, lots more air flowing through the engine now.
Really curious to see what this thing is gonna do when I get the carb tuned in right, more compression and my expansion pipe exhaust built for it, I'm betting on 45MPH with the 34T sprocket possibly, need to get my Tach hooked up on it so I'll know what kinda RPM's I'm turning it at what speed.
Sure am loving the Dax......... best and smoothest running engine I've had yet...... gonna end up with one of them on all of my personal China girl builds, as I will replace the engines I currently have, they are good running engines but I just really like the extra smoothness of the balanced Dax lower... really nice.
map
map
