mapbike
looking at an engine I had in box today that I had ordered a couple years agao from LEB on ebay, its the one that has the drilled crankshaft just like the lowers dax has been advertising as being balanced and trued.
the transfer port cut outs in the case of the LEB engine are pretty darn nice and very closely match the jug and base gasket, this cant be said at all for the cut outs on the dax lower, looks like I'll need to tare this dax lower down and do some work to get things matched up if it ever gonna be a screamer like I'm hoping to build out of it.
pics below show what I have spoke about here.
Dax lower case in pic above.
LEB case lower in pic above.
side by side comparison above, LEB case on left and dax case on right, big difference, may just pull crank and bearings out of Dax lower and install them in the LEB case and save myself a bunch of port work.... not sure yet.
just thought someone might find this interesting and also wanted to show that truely these engines aren't all the same, and I believe these little things are why some of them perform so much better than others right out of the box, by the way LEB called this engine the X80 and it has the longer curved clutch lever and the case was painted gray instead of being raw Aluminum like most of them are.
map
map
