stromberg97
What you have is a 3/4 inch steel pipe elbow. It should have 3/4 cast into it. If it was cast iron the flanges around where the pipe screws in would be a lot thicker and would actually touch each other.
The pipe he is referring to is probably 3/4" i.d. black steel pipe. It is plenty thick and pretty strong, the only issues is it is typically softer steel than the tubing you'd buy from a metal place and the wall thickness will vary more than tubing. I've used it plenty of times for little projects and it would probably be fine for sleeves in a bike frame, it actually welds really smooth compared to regular 1018 mild steel but I wouldn't suggest it for a whole frame as its not that much cheaper than comparable sized mild steel tubing and the tubing would be uniform in strength.
So what do you think about using it in this application, especially for a 225 pound circus bear? I like that bear and don't want to see him hurt his ample butt.
SB
I wouldn't worry about the fitting failing but I would worry about the pipe cracking at the threads. It might not support a load on the end of the pipe acting as a lever on the weakest point being the threads. Remember material was removed from the thickness of the pipe when it was threaded.So what do you think about using it in this application, especially for a 225 pound circus bear? I like that bear and don't want to see him hurt his ample butt.
SB
