Otto how tall is this engine with out the gas tank?
Thanks
No idea on how far along you are with this engine. Let me share with you some things learned through my personal experience with these clone engines.
Removal of gov and pluging its hole results in no oil on the outside of the case. I'll explain. Ive ran my first one by just disconnecting the outside parts. Then at high RMP a fine sheen of oil comes out around the rod and then dirt starts sticking shortly after. I love my rat bikes with all there rust and dents, I just hate dirt - oil covered dirt eww.
The engine in your pictures sure looks like a flat top to me. Tell me its not an OHV, please. Am I just blind?
I have 5 of the doodle bugs and it sure looks alot like the same thing. Acutally looks exactly like a drege motor from I picked up at a tent sale at HF with the oil sensor inside. I would get rid of that and plug it off too.
You said someting about HP in the thread too. It is my undestanding the 2.5hp rating is at 3800rpm and removing the gov allows you to gain the rest of the power band or aprox 3.5hp This is what Ive been told.
Stories or fact? I've only seen em blow apart rods etc..wheel won't help that
First of all, agk seems to be using a bit of a scare tactic to make sales. Secondly, there is no way an aluminum flywheel can be lighter than a plastic one. I can see a flywheel exploding on a heavily modified engine, but running it stock (other than removing the governor) shouldn't be a problem. My buddy Jay (jbcruisin here on the forum) is running a 99cc predator with the governor externally disconnected, and to my knowledge has not replaced the flywheel. I'm also not going to replace my flywheel, whether I keep the engine I've got or replace it with a 79cc predator.
I think none of these motors have a plastic flywheel to start with. I do not see any aluminum flywheels available for these small engines. The need to replace a flywheel on a hi performance engine is due to the hi rpm's and the way the magnet is installed, the magnet has pins that secure it vs glue and screws. The video from Agk is real and true life, and could cause extreme damage. I really am not worried about these small engines, the first thing to go will be the rod. Plus they don't make any more power after 5500 rpm without adding a cam and head work.
