Don't twist the throttle so hard ;-}Driving me nuts! I'm constantly snapping my throttle cable at the twist grip end where it connects to the bulb. What do I have to do to stop it or at least slow it down from snapping?
Is the cable actually breaking or just pulling out of the silver 'bulb' piece?
If the cable end is frayed it must be rubbing somewhere and it just goes down through the L tube so it's tough to say.
Have you got pics of your set-up? It might be easier to figure out what's happening if you do.
Nice build, looks cool. When you get a chance take a few close up pics of the throttle and cable for us, assembled and apart, and we'll get this sorted out.
Unless of course you have something funky going on inside your twist grip which is really what it sounds like if it always breaks there.
Maybe the hole in the twist grip where the bulb anchors is too small and binding which bends the cable back and forth over time and breaks it. I'd also check for a sharp edge where the cable enters the steel adjuster.
That's what I'm wondering about. A rough spot, some point of friction, something has to be working and wearing on the cable itself in the break zone. They are mass (often poorly) produced parts, there's always a chance of bad molding or machining.
I've had problems with the clutch levers needing cleaning up so they won't eat cables, but so far no probs with any of the throttles I've had my hands on.
