motorizemyride
Hi all,
I want to do a chinagirl build on a mountain bike with front and back disc brakes. The idea hit me to simply get a motor with a right side drive shaft, chain it to one of the front gears, and voila. Sure, you wouldn't be able to shift the front gears, but you'd still be able to shift the back ones.
What are the community's thoughts on feasibility/difficulty? Do they make right side drive chinagirl kits? Obviously I wouldn't be shifting while the engine is at full RPMs (likely not at all while the engine is running) as that's basically asking for trouble, but are the components going to be up to the task?
Also, I'm curious about 29'ers. If the above idea proves to be utterly ridiculous, what should I be considering for tooth count on a sprocket? What are the pluses and minuses of using the larger tire size?
Finally, what are the benefits of rear shocks vs. just having shocks/springs/whatever incorporated into the seat/seatpost? It seems to add an unneeded level of chaining/sprocket complexity in my mind, and as a bonus robs you of a teensy bit of power, but there may be tangoble benefits I'm unaware of.
