you can say that again!There are several topics in play here...
Medicine, engineering, safety, & fashion....all in one paragraph! Epic post, man
shouldtryreadingitonaniphonehahahayou can say that again!
Actually you're only partially right. Mounting these engines with rubber allows the motor to move fairly freely setting up a resonance. We've used rubber for three different motor/bike combos and they all have had terrible vibration, which stopped after the rubber was removed.There's no way, it's just not possible. I understand it doesn't get rid of the source. But any form of insulating that can absorb any kind of movement will reduce vibration. If this weren't a fact then rubber bushings wouldn't be the standard vibration/noise reducer for almost all machines and cars. From air compressors to CNC's, cars to planes, rubber bushings/insulators are used and are effective.
Now i get that one dopey little wrap with 3mil roofing rubber isn't going to be very effective. But anything that can absorb/dissipate the resonance will reduce vibration.
Lead sheet works pretty well too.My old boss a retired engineer from Aerojet suggest we use delron or nylong sleeves and they work very well.
I don't use any rubber. Granted I did upgrade my engine mounts from M6 to a 5/16-18 just because I thought it looked weak to begin with.Your gonna bust the fasteners to the motor! Might read through this? http://motorbicycling.com/f6/rubber-not-27364.html
You can protect the paint with a couple of layers of vinyl electrical tape. No need for rubber.I don't think rubber would 'increase' the vibrations maybe just allow the engine to vibrate but still the ONLY reason I'm using rubber on my mounts is to I don't scratch the **** out of my bike.
Wow cant believe I never thought of that. LOL Cheers manYou can protect the paint with a couple of layers of vinyl electrical tape. No need for rubber.
Here what I did:take the motor apart and rectify the flywheels (weights)from the crank.Eliminates the stress in bearings (they became loose),Stop shaking the carb.Install a reeds valve (billet) also cuts the vibs also improves the low rev torque(need a larger jet for some carbs).The rubbers should be between the tubes of the mount and the bike,applies for choppers and cruisers with separate mounting (not directly to the bike.After that you can use foam,and handlebar lead weights(like a scooter or motorcycle,mine were made out of fishing cast leads) for personal confort.Improoving the muffler and/or lighter (and perfect round..) flywheels helps too (better dem for semafors but less inertia for the ups.Cheers and keep it street legal.I was going to keep my mouth shout about this but after doing 3 bike around mt house. I feel like I have to tell.
one day in a drunken argument with a friend (who doesn't even ride) say fill it with foam. You know the old light bulb click ding ding. SAME BIKE, SAME SET UP.
A little expanding foam in the down tube and seat tube "Fill'em up" has an amazing affect on vibration. Almost just absorbs it all, I do have the standard rubber motor mount raps but that did very little any ways.
Hope this can work as well for you guys as it does for me and my group.
Way to heavy, weight is the enemy- I like the foam idea, I wonder if it might strengthen some frame flex also?I've used lead shot in the handlebars before too with good results....
