moonerdizzle
finally got around to working on the AMF and decided it was time to do a build thread on it. I ordered a brand new motor from BGF, and i was really surprised with the quality of this motor, no bolt on weights on the crank, the wrist pin bearing was much wider than the old ones. Right away after I got my kit i tore it down and split the cases to put in some higher quality crank bearings. while the case was split i also did some work on the transfer ports to run a reversed jug. The jug has been ported out and has reworked transfers.
And yes, this intake is totally stock, port matched from the factory
