Seems like pre-ignition. Mixing in extra oil is often to your benefit, especially when rolling WOT all day. What was the trouble with the CDI? could it have caused pre-ignition? Rolling down the hill with a closed throttle while the rear wheel pushes the crankshaft may cause the cylinder to dry up and seize, but not detonate. Unless it seized and the CDI fired off one last time, blowing the hole out and un-seizing the piston...hehehe
Adding more oil will not help, and in fact can lower octane with will encourage detonation, and a lean fuel to air ratio.
The screw coming off the cdi that has the plug cable on it snapped off, probably from enough high frequency vibes and some lateral pressure from the cable being too long. I'm pretty sure that caused a huge change in timing and that's what did it, but I couldn't say for sure. But it didn't seize, as there are no markings or anything on the cylinder walls and the piston still moved freely. Plus I heard the spark snapping noise of the broken cable screw JUST before it happened.
I just know from experience with high compression running high-octane in 11000 RPM engines. 25 to 1 mix btw![]()
Except these aren't high octane/high compression 11,000 rpm engines.
Just "adding oil" will not help the situation when he already has a detonation problem...but you know that from building out monster engines, right?![]()
sounds like you could use a piston that could withstand higher temps. i got some in the swap and shop.
i got to say tho, that is the most mangled china doll piston ive seen yet
We are all ****ing experts around here. Go ride a bike or take a running leap through a rolling rim...
Somebody has his panties in a bunch.
the only thing really holding these motors back from high rpms is the stock cdi. if you make your own cdi that doesnt advance the spark like the stock ones you can get higher rpms out of your engine. 9000 isnt out of the question
