SuperDave
I've been toying with this idea of polishing the combustion chamber to a mirror finish to enhance performance. My reason for thinking is thus: a semi-smooth or textured surface allows carbon to deposit, becoming a heat sink & lends to pre-detonation - knock & ping. If it were mirror smooth, it would:
A) Reflect the heat back into the cylinder, aiding the expansion of the gasses and push down on the piston a little bit harder,
B) Discourage carbon buildup which might lead to pre-detonation,
C) Run cooler - the heat isn't absorbed as much into the head but goes out the exhaust.
I've looked around on the forums but haven't found much on this subject. I'm wondering if anyone has tried this, or if anyone has justification as to why I SHOULDN'T do this. Polishing the piston face might also be help too. I figured I could do this when I remove the head & jug to lap (sandpaper taped to glass) the mating surfaces for better seal (already blown 1 head gasket already) & maybe a wee bit of a compression increase.
