Holy CRAP! Where's all this come KCvale? I HAVE a Skyhawk. And what the **** makes you think I've made 'Performance Mods'? I have a standard 66cc that I've made minor adjustments on based on a lean-condition and a mysterious run-away issue. Hence, my positing a query based on an unusual condition which I'm confident a few very intelligent mechs on here have come across and can share a solution with me on.
In any case, you knuckle-head, I COMPLETELY disassembled by baby this afternoon and checked all her seals and gaskets, as I did to the NT. For good measure, I replaced the head, head-gasket, base-gasket, and while I has the case split, I replaced the flywheel-bearings for good measure. I STILL have the lean behavior as well as the deiseling (thought I'd solved it). Anyway' the engine temperature has been within nominal limits, and I'm still running it; and it's running superbly except for the run-away. In fact, I' on the road nw.I am baffled but want to figure out WHY it's doing what it's doing. If your answer to engine problems is "just buy a new one, you're on the wrong site. Also, I can get a new engine for $89 delivered, so suck it.
