So, I have my very first vaccuum leak, and it's driving me insane. I have done absolutely everything to determine where it might be (short of splitting the case), and have actually sealed the magneto and clutch covers SIX DAYS TO SUNDAY and short of splitting the case (jinx) to inspect the seals. Took the head off and the gaskets are pristine. As is the intake....tore everything down and inspected the gaskets...all good. Sooooo...I've never had to deal with this issue, and I'm about 10 miles from home (having a couple of beers right now). Engine's running great otherwise, and the temperature's acceptable. I cut the engine when I need to idle since it's running-away when I release the clutch. It's actually run-away while the kill-switch was on a couple of times...dropped the clutch @ stop to remedy that (how the **** does that happen?).
Am I safe to get home provided I don't allow the engine to run-away, and keep the temp down?
The engine's running excellently otherwise...I'd hate to destroy it.
PS: I used WD & Carb Cleaner to check fer leaks. No dice.
