GasX
I just got my KW machine Works chain tensioner and when I put it on the frame it made obvious my chain alignment issue. The drive sprocket on the transmission and the rear sprocket don't line up that well, but I thought the chain tensioner would sort it out. If you look at the picture, you'll see that the tensioner is not remotely in line with the rear sprocket rendering it useless. However, you can see a spacing nut on the axle in the picture. If I remove it, I think everything will line up, but won't my frame not like the reduced width?
Any thoughts on resolving this issue would be appreciated. Perhaps moving the spacer to the other side might work...
TIA
TIA
