Predator303
Ooooooooooooook here we go......
As some of the people here know. I am building or basically finished building my first complete ride. For details and pics, here is the link to the thread:
http://motorbicycling.com/showthread.php?t=43358
Now.. I wanted to use my old china cr*p kit rear sprocket because the only way to install it was by drilling through both walls of the hub because I use 68 spoke rims (also see details in the thread of the bike).
I originally planned to use
12 clutch #35
22 JS in #35
11 JS out #41
44 rear #41
but I ended up with
12
15
10
44
because the JS in sprocket with mount..
http://www.affordablegokarts.com/mm...re_Code=A&Product_Code=0502&Category_Code=PCJ
http://www.affordablegokarts.com/mm...e_Code=A&Product_Code=0520*&Category_Code=PCJ
.. did not fit the mount and neither did it fit the shaft with the key, it had a lot of movement on the shaft so I replaced it with a 15t I had lying around because in the beginning I thought the problem I have could be caused my that. Sadly my ratio got MUCH higher with that exchange.
So here is my actual problem:
When I accelerate from dead stop it pulls away with the killer torque with no problem at all, regardless of the high gearing, but as soon it rolls with 5mph and I keep using a little bit of throttle, the chain vibrates like crazy around the jackshaft and especially after JS out to the rear sprocket between JS out and tire. I deleted one possible cause after the other, including grinding the JS out sprocket because the chain used to jump there and didnt get in correctly so now its grinded like the rear sprocket so a #40 bicycle chain could fit but nothing of what I did changed the problem that as soon its rolling, its "crunching" like the chain doesnt get into the small sprocket from JS out because of the combination of turning speed and vibration. I installed two chain idlers/tensioners today and its slightly better but only if I pull the throttle with almost close to zero throttle. As soon I give it some juice, it sounds and feels horrible all the way through the frame. Very unhealthy sound.
So right now after installing the tensioners I also cut together a BMX chain from my friends store to the right size and its a tiny little bit better, meaning I can go higher speeds if I accelerate extremely carful but I can literally almost not use any throttle or if it slightly goes uphill it crunches like crazy.
So with all that done it MUST BE the small JS out sprocket. I thought it might be too small and because I am using a #41 chain, it might not get around quick enough due the small size of the sprocket and I thought maybe I needed to change my setup to a #35 all the way to the rear too, but then I looked up a conversation with buck0 (David) from whom I bought the engine and I realized that he too was using a bigger chain for the rear:
"I ran a #35 chain to the 22 tooth then the other side was a #415 chain and used a 9 tooth"
Even smaller sprocket than I did. So what in the world could be the problem???
At this point I start to wonder if cutting the tube of the jackshaft (also explained in the thread) could cause that vibration, but then again, when its rolling without throttle it works. The problem only comes up when I use throttle.
I know the high gear ration doesnt help but right now I doubt that if I had a 60t sprocket in the rear, anything would change since I cant even get to a speed where the clutch engaged completely.
I have a million options like getting a 26t JS in sprocket and a larger JS out sprocket, or switching to a #35 chain and sprockets all the way but before I waste another week and 100 bucks for nothing, I would like to have some help because I really am out of ideas. I tried everything I could.
Thank you very much!!!!
12 clutch #35
22 JS in #35
11 JS out #41
44 rear #41
but I ended up with
12
15
10
44
