I figured, simply because all things have been tried, that some one's built one of these kits with a version of the rubber mounts like come on the new Harleys. I was imagining utilising the bushing found on new chain saws or roller blade wheels I dunno
Do not mount the motor in rubber. This has been discussed here over and over. By doing so you are NOT eliminating the source of the vibrations but simply isolating it to the mounts and the mounting fasteners. It is not a 4 stroke Harley, or a Honda, or a Chevrolet or a Cadillac. It is a 2 stroke, single cylinder engine that will produce vibrations.
My two stroke Schwinn runs great, it tops out a bit over 30mph with a 40T sprocket. There's little vibration on that bike, I wish I could say the same for the four stroke.
Have front suspension, crappy, but its there.
I have the corny grips that they all game with. Where can i get a different throttle grip?
I need the big sprocket for the hillslol
Weighted handle bars? How does this work exactly..
Balance engine... simple as it sounds?
Improve mounts, thats what i was figuring, how would i go about doing that?
Jumpa,I cut up an old bicycle tire tube and wrapped it around both points where the motor mounts go I actually super glued the rubber pieces to the frame tubes so I could avoid over lapping the rubber and I didn't want the bulk of electrical tape I did this on my second build an it has considerable less vibration than the first build , I also wrapped rubber tube around the bar before installing my gas tank keeps it from moving around and cuts down on a lot of vibration we get from there as well .
