The metal frame on the bottom is to big. How do I get my motor on if the tube is too big?
Thanks, Vinoy
Thanks, Vinoy
Just wondering why you used threaded rod connectors instead of just buying longer bolts. There's no requirement for studs. Allen head cap screws work well and by using bolts instead of studs you have only one set of threads to worry about. Ace and most other hardware stores will usually have metric cap screws. You'll want 6mmX1 in the proper length.My tube was oval, so I got longer bolts to fit.
