I lightened the pic up some so we can see the sprocket.
Thanks, so what do you think?I lightened the pic up some so we can see the sprocket.
I am really stressed out about the whole thing. I have put a lot of money into this thing mostly on replacement parts ( I got my new hardware kit today ) But I have learned to be patient. And by rear sprocket do you mean the one on the back tire?No need at all for sorry. Your among friends Stuck.
Your chain was hitting the (in picture) upper nut? If so, thinking your rear sprocket is not out far enough. Can you post a pic of your rear sprocket? The "rag-joint" can be a major problem and really throws people. (lol, figuratively speaking)
No worries. You will be up and running soon. Don't let it discourage. The hair pulling is just part of the fun. Then, really adds to the joy when ya get her going! (an' you will)
I bought my universal front mount yesterday, when it gets here I can.from the pic it had to be a miss alignment problem because it should have cleared the stud in question it would be close but not touching.
while you put it back together can we get pics of the engine in the bike?
The sprocket on the bike of the tire is straight, no bending.yep the one on the back if it "dishes" towards the bike that could be the problem
also dont worry it will work out we ALL have had problems along the way to making ours work the way we want
I'm sorry i'm not sure what you mean by offset.i mean does it have a offset to it or is it just flat?
Completley flat siris the sprocket completely flat or are the teeth off to one side?
like the shape of a dinner plate
Those rubber pieces were/are going on the front and rear mount to reduce vibration. I will send a picture of the rear wheel tommorow.if you look at it closely,it doesent really dish,but the ring where the teeth are is set to one side.if at all possible post a picture of the rear sprocket mounted to the wheel.
every one of us replying want to help you get to riding.
i see pieces of rubber laying beside the motor,were you using those inside the mount?
