heyscuba
I'm mounting a motor kit to an old 82 Murray Cruiser
and I'm starting with mounting the sprocket, but there's a coaster brake and I'm having a problem in this area,...
e-mail me if you can help,...
First off, the sprocket doesn't fit over the hub assembly,
I'm making the hole bigger now by slowly reaming it out with a Dremmel Tool,
but I fear once I get it to fit over that part IF I put that outer (thick) rubber washer on the wheel and then the sprocket on it will all stick out to far and I will not be able to put the coaster brake bracket into it's slot if supposed to fit into.
Please HELP!!!
A) do these kits work with coaster brake bikes?
B) do I absolutely need that outer rubber washer,...? or can I do without it or try to find something thinner?
[email protected]
Please HELP!!!
[email protected]
