Genisisonyx29
Here is the chrome one i gave to my son..![]()
how did u mount the sprocket. is it say to skip every third hole on the sprocket?
I am in the process of mounting a 99cc Predator engine on my frame. Has anyone mounted the engine with the cylinder in a vertical position? I know that the 212cc engine has been mounted with the cylinder in a vertical position by members of this Forum.
Any input or helpful information would be appreciated. Thanks
Just a word of warning to anyone planning to buy this bike . This bike was my 1st build and was a real pain every step of the way but after getting the job done it rides beautiful and looks cool . After putting around 20 hours on it i blew out the rear bearings and cracked the hub . That's when I found out YOU CANT BUY REPLACEMENT PARTS FOR THIS BIKE !
I haven't gotten that far yet but I'm sure the 48 spokes is going to be a problem but I think manic makes an adapter for that. I think there is probably enough clearance for the chain. The biggest problem I see is that the seat tube is 32mm and the downtube is 45mm. The bike is huge. As long as I have to custom fab motor mounts I think I'll put either a Lifan 2.5 or a Greyhound on it. I might try and adapt SBP front motor mounts to both the front and the rear. The handlebars are 25mm but choke down to about 22mm where the grips are. I think the throttle and clutch will go on without much problem. I'm still trying to finish up an O.C.C. Chopper so I'm about as tired of mounting problems as I'm going to get for awhile but all in all I think this project would be worth the effort.
I did blow out the rear bearings but that wound up to an oversight of my own and after getting in touch with Kent they actually sent me a brand new rim at no cost and no questions asked.
(first build...3rd motorized bike) I got the Onyx 29" Beach Cruiser bike from Walmart...no instructions pertaining to the bike that was actually sent. NP, it was kind of intuitive and took about 45 minutes to put together & tighten up. After removing all the little white stickers all over the thing, I think it looks way cool. It's light for such a big bike (aluminum frame) and easy to pedal. I bought a Chinese motor from Bike Berry (BIG MISTAKE). When I opened the boxes it appears that the components spent some time in a Gorillas cage. More than 3 fins bent together, black paint on about half of it?? & the other areas chipped off (paid extra for the black...but they didn't bother with making the bent up chain guard black or the muffler), mounting screws....one was almost doubled over...some other parts weren't in the box, as far as the prick on the useless DVD....I could give him a slap'n! It displayed parts already together that came in pieces & he was working with a different motor. (I now am intimately familiar with how the carb & cable works together, thanks to an hour on the Internet.)
Anyway, I'm impatient and didn't want to return the engine if I could get the $204 piece of junk to work.
So it began...nothing about this 29" bike is standard or fits well with the "engine" I purchased. The handle bars on my onyx are straight 1" all the way through - apparently every handle bar in the known world is 7/8"?. Neither the clutch or throttle would fit. (which created creative struggles for me & my step dad, who has every tool in the world & way more mechanically inclined) The gas tank needed custom strapping, although I bought the U bracket to mount the motor, the rear, (bent screws weren't log enough..got pipe straps & drilled holes) The cables from the throttle to the carb were about 8" too short so had to splice some additional and solder them together. The rear fender rubbed on the chain as well as the rear fork. Had to cutout a section of the rear fender (Looks too cool to just remove) & had to adjust the chain guide about 5 times. (oh yeah, by the way you can only get 6 of the 9 sprocket screws on no matter how you hold your mouth)
Anyway, I could go on but will spare you. My first build was a nightmare but I did learn allot. We managed to bend /struggle / & modify EVERYthing to come to the point where I could peddle off in an attempt to start the motor. Which did start after the 5th attempt. It took 2 trips to Lowes and approx 11 hours.
I do however need a 1" twist grip throttle. The only ones I've seen online are for mini bikes. Would that work for my 1 inch bicycle handlebars? Right now I have a small pair of vice grips that I am pulling on. LOL not too safe!
Thanks
