JB weld in the studs on a new motor? That doesn't sound right. Personally I would never use JB weld to lock a good stud unto solid threads, I would use red loctite instead. Perhaps if the threads were stripped already some might use JB Weld to affix the stud, but I would go in the direction you had suggested, the time sert or helicoil repair. Not sure if you could tap it out to the next size stud (probably standard thread) without drilling the hole in the head and jug? Maybe somebody has done this already and knows what works or not?? That said, I would wait to hear back from the retailer about the situation.
I certainly sympathize with you about wanting to ride... But this begs a question. If this is the third motor you have that has failed do you possibly have enough parts to build up one good motor and ride?
