BMX Brake Adapter?
Dave31
I was sure at one time, I saw I believe it was a BMX parts supplier. It was a adapter to go from a single pivot side pull brake to a Linear-pull brakes or direct-pull brakes.
From Photo 1 brakes, a adapter to mount photo 2 brakes.
Now I can't seem to find it?
Hey Dave, I'm sure you've seen them on a couple of my bikes over the years.....you can mount them on front or rear as well.
URL=http://imageshack.us/photo/my-images/827/img1049hf.jpg/]
[/URL]
I used to get them at Dan's Comp but they no longer carry them. They do however carry the adapter for the U-brakes (Dia Compe 990 and others). Just another possible option for you.
dnut
Dave,
DNA Powerstop-V is still being manufactured, but couldn't find a distributor in the USA - only UK
http://www.dnabikes.com/powerstop.html
Might want to keep an eye out on BMXmuseum.com. Sometimes they come up for sale.
It might be best to have someone install some brazons. It might be cheaper in the long
run.
As a possibility, you might want to look at modifying a horseshoe for a horse or pony or a throwing since they do come in different widths and lengths - serious! Just might have to shorten the length or bend to modify the width. Just a thought.
http://www.wowhorses.com/horseshoe-sizes-chart.html
http://www.texicantreasures.com/123293_IRON_HORSESHOES_SMALL.html
http://www.farmandfleet.com/products/041000-pony_horseshoe.html#.T-FopRdilN8
Good Luck!
Chris
AKA: BigBlue
Dave,
might want to keep an eye out on BMXmuseum.com. Sometimes they come up for sale.
run.
Good Luck!
Chris
AKA: BigBlue
Or use the U-brace off a suspension fork with the brake bosses already mounted.....just bolt and clamp.
And yes, it's easy enough to fabricate one of your own......yes it is.
Cheers,
scotto-
Thanks guys thats it! Now that I see it I don't see why I cannot make one. Looks simple enough to fabricate.
Have not accomplished much, hopefully tomorrow I can get it finished. Found something that just might work?
Just for anybody that is interested, I found a site where someone made their own v-brake booster which is similar to the old v-brake adapters. It was machined out of aluminum, but can be made out of steel. It is a full size drawing which you can print out and trace onto your metal, as a pattern. Extra holes were drilled in the legs to lighten, as well on the top, left and right of the center hole.
*You'll have to change your print settings to "Landscape Mode" and change all the margins to 0.25 to print out properly.*
http://motorbicycling.com/attachment.php?attachmentid=49348&stc=1&d=1340781884
Sheldon Brown on fitting considerations for cantilever studs.
Good Luck,
Chris
AKA: BigBlue
Ibedayank- In the first post on this thread Dave31 wants to change his single pivot side pull brake to Linear-pull brakes or direct-pull brakes, those two types. I should have been more specific. your name looks familiar...
