Norman
LORD VADER Moderator
I'm in the thinking stages of making a pipe for these bikes it won't be a tuned one per say but will be better than what comes on these bikes stock.
The big problem is it take a lot of time to make and weld so I'm looking at a cost of around $100.00 for each pipe. What I'd like to do is use is send the customer paper templates that they would cut off their head pipe and tape the patterns to their bike for the clearance and so things won't hit the frame pedals or chain sprocket etc. it will also include a muffler either welded solid or with a removable baffle. I'm also thinking about the so called poo poo pipes they should be very easy to make its just getting the bends right to clear the sprockets,pedals etc. again I might be able to make them with some kind of a bike diagram and some measurements.
They all will be unpainted and no chrome what do you guys think would it be worth it to you?
I also could do the welding mods to pipe's you already have if you provide me with measurements and mark the pipe on how to weld it up and supply all the parts.
My pipes that I make are very quite and work better than stock you can see them on my bikes here on the forums if you want to go for a tuned pipe you will need to provide patterns I can use and a mock up in paste board of the pipe I work in English measurements so don't try metric I can do some things in metric but don't want to mess with it building exhausts.
please respond if your interested.
Norman
Norman
. I guessing about $50.00 to $100.00 but that is only a guess a Harley type pipe might even be cheaper as long as the dia. is not over I". I don't have benders to handle over that. Now if the dia is larger than 1" but is straight that might not be a problem. I can also make different type of baffles to get it quiet or if you want the neighbor's to start shooting make it loud. something you might try is make the pipe out of pvc the best you can and use poster paper hanger taped on where you want them and I can use it as a pattern.
