Hi Guys,
Thank you for your suggestions. I do have gas flowing to the carb. Today I disassembled the throttle assembly to make sure I had the ring on the needle valve on the second groove from the bottom. Put everything back together and tried the bike again. It ran for a little longer. We live in hilly country so I took it to a nice downhill area, got the motor going pretty good, but then it threw the chain. I am going to tighten up the chain tomorrow. I did notice that the chain tensioner guide wheel doesn't seem to go around. If I tighten it enough to keep it in place vertically, the wheel doesn't turn. If I loosen it up so the wheel can turn, it slips down in its slot. I am thinking of just removing the cussed thing, and take links out of the chain to make it tight enough and then if need be, use the tensioner on the pedal side. Any ideas on this?
Tyrslider, I did have the choke lever up, I thought that was the position it was supposed to be in for a cold start. Is that not right? I did try it with the choke in different positions, but it didn't seem to make too much difference.
