PERFECT! works much better! I shorten the cable and cable tyied it straight from the handle bars, Half way down on the down tube untill it hits the black box then straight across to under the carb to the arm. Before the cable was 1+ meter long!My kit had a frayed clutch cable right out of the box. I replaced the cable with one from Wallyworld and also replaced the cheap russian style lever with a brake lever that matched all the rest of the levers on my bike. Unhook the cable from the clutch arm and make sure it moves freely inside the outer jacket.
Thank you
