There is a small plunger that can fall out,when you installed the chain(that happen to me)it is located in the center of the drive sprocket,If this happened the clutch lever on the motor would be very loose and would not disingage the clutch. But if that is not the problem then the star adjustment that is located under the right side egg shaped cover on engine, may need backed out just a bit. There is a screw that keeps it in place that must be removed first. Do not grease the gears! Did that and had to take it all apart to clean it off after the clutch slipped so bad it would not start. I love this form. The people here have helped me fix so many problems. Im sure you will fix the problem, so please post the fix when you do.
