wayne z
OK, I'm curious as to how the oil gets back to the tank. Are you sure splash lubrication is part of this design? I thought splash system had oil stored in the crankcase below the crank with a dipper on the rod.
What splash this engine has is from the pumped oil leaving the bearings and being slung/blown all over in there before being coughed out of the 2 holes.
By the nature of a crankcase design like this with the enclosed flywheels, There is never much oil in it's crankcase. They use a scavenger pump, of larger displacement than the main pump, to insure that oil does not pool in the crankcase. the flywheels and rod can not run submersed in oil.
I have an '82 Harley that if I let it set a couple months, some oil leaks into the crankcase from the oil tank. When I first start it after sitting, It spits out about a cup of oil thru a special valve that's installed for that purpose.
Harley's also use a timed,rotary valve in the crankcase that lets crankcase air out on the piston downstrokes and closes on the upstrokes. This is to keep a slight vacuum in the crankcase so they don't leak any more than they already do.
The total air volume in this Gravely crankcase is very small compared to a normal, external flywheeled engine, and the piston displaces a LOT of air volume in the crankcase with each stroke. There's no way you could keep an oil level in the crankcase with the engine running. If you did , the oil would be churning and frothing from so much windage that the motor performance would suffer.
Maybe we could have a large hose like 1.5" hooked from one of the lower crankcase holes to the top of the oil tank, and use a large Gravely type breather cap on top the tank, letting the crankcase breathe thru the top portion of the tank, allowing the oil from the breather to pool in the tank.
