Going for the worlds fastest moped, turbo-fuel injected
t-rat
Hey all,
This is my quest to have the worlds fastest true moped,to have usable pedals. I have a budget of about $3500 to get as much of it done as i can so i need a lot of help from you guys out there with ways to cuts cost as much as i can. ANY IDEAS AT ALL lol from sponsorship to a good way to get parts cheaper
Main parts list Parts List::::
Motoped Parts kit
http://www.shuttlebuddy.com/shopmotoped.html
EFI Kit
http://www.mbe-motorsports.com/catalog/product_info.php/cPath/22/products_id/190
Turbo IHI RHB31 3T-505
http://www.chinese-parts-canada.com/turbocharger_fuel_injection.html
(im going to buy one from ebat for a bit cheaper)
155cc high output crate motor
http://shop.pitsterpro.com/close-ratio160crateengine-3.aspx
(possibly another ebay pickup)
thats about $3000 out of my $3500
I'm going to need....
Rear Tire cost???
1) 24 in high speed tire
2) spokes
3) inner-tube
4) rim
5) learn how to lace it
Front tire cost???
1) 26 in high speed tire
2) spokes
3) inner-tube
4)dual disc brake hub
5) rim
6) learn how to lace it
triple crown forks
handle bars that bold on the the forks like a street bike
gas tank
crank arms
pedals
chains
seat
flaring
gas lines
tach, speed, oil temp and boost cluster
throttle cable
head light and tail light
so guys what else do you think ill need and any ideas?
probably not....
meaning that it it swill start with a 155.7cc pit bike motor and then get a big bore kit eventually.
i am going for the worlds speed record 100%
Monarch is right. it would be a motorcycle.
Mopeds are 50 ccs and big bore kits go up to around 70 ccs.
I have used turbos for many years and there is a big learning curve. They also need an oil source.
the motor has a internal oil pump, and frankly sir i, just don't give a damn about engine size ;] this was just the biggest motor i could find that will be a direct bolt into a Motoped/cr50 frame that has a internal oil pump to feed the turbo.
I'm only looking to boost the motor about 5 PSI (maybe up to 7 PSI if i can justify it with myself)
As for legality.... most cops where i live are pretty cool about these motorized bikes...and I'm pretty sure a couple of 50cc stickers will help keep them at bay.
This looks sweet! I will keep an eye on this one.
"Faster and faster until the thrill of speed overcomes the fear of death!! "
I love this quote. Hunter S. Thompson Right?
Hey all,
Motoped Parts kit
EFI Kit
Rear Tire cost???
2) spokes
3) inner-tube
4) rim
Front tire cost???
2) spokes
3) inner-tube
5) rim
triple crown forks
gas tank
crank arms
pedals
chains
seat
flaring
gas lines
throttle cable
Do it with some class and style..... You need one of our frame and fork sets:D
Actually, Roland and I have been working on just such a project for the better part of a year now! Trust us, making something like this actually work well is not quite as easy as it sounds, and the typical artists/builders on the forums are not usually that well versed in chassis design and setup.
This is not intended to be a jab at anyone, but when you start to move beyond loud stationary engines and discover real horsepower, the learning curve can get real steep. We are having big fun with our project, and think that more people will agree that these little engines are a great platform for MB use!!
this would be cool to do ... but do it right and do it at bonneville ... you might get lucky , and there may not be an existing record yet . BUT , you would have to construct the bike acording to bonnevilesl regulations ( mabey ... depending on the speed you are attempting )
oh wait ( The fastest recorded speed for a moped is Blackball's Motron with 86cc Minarelli V1 under the 100cc A-G Class at 63.656mph )
Someone some time ago ran a double engine Whizzer @ Bonneville. I saw a picture of it in a newspaper. I don't remember if it had pedals or not. It was a record breaker in some class or another. 93 +/-MPH? Memorys will fade.
if you're going for bonneville, good luck. with a 155cc turbo charged engine, you've got a lot of competition. it doesn't matter if it's in a moped frame or not, it's the engine that counts.
here's a list of the records at bonneville. remember, everything's slower on the salt, and you gotta make 2 passes without it blowing up.
http://www.scta-bni.org/Bonneville/BNI_records.htm
if you just want the unofficial, armchair, moped fanatic record, then it doesn't matter what you do to it as long as it's fast.
personally, i'm hoping to go for the 50cc record either this year or next. not sure which class, but i think it's one of these: the "M-G" class record is 84.448mph, or the A-G at 85.927mph.
the supercharged 50cc streamliner record is 131.545mph, in case you were wondering...
Have you been to El Mirage? its somewhat local, and you can get a b%ttload of info there. What else do I think you need? More Money! anything is possible... but $3500 won't get you close to any "world record" unless you're eating hotdogs! GOOD LUCK BROTHER!!!
bairdco, thanks for clearing that up. For some reason I thought that Whizzer was faster. Now, where is my Whizzer? I know I left it around here somewhere.
thanks for all the info guys, but im going for it lol
...i've been living on top ramen and hotdogs for a while already lol so im fine eating more.i have been looking around and decided to build the bike first, then add the turbo and efi after i get it running
