KANNONBALL13
I have a new 66cc grubee and a CNS carb. The problem is the air/fuel screw is flat. I has no notch. I cannot use a screw driver to turn it. Am I missing something?
I was ridding and noticed a sudden spike in speed. It lasted about 30 sec. and then died. I was out of gas. so i filled up and the bike stared to loose power and speed. I turned the fuel off and after about 45 sec it spiked.
I think you may be right on adjustin the tab on the float. ( bending it away from the float to shut off earlier) thanks for the reply.
I will look at sediment in the tank as well. I want to firts adjust the float tab,
then ride it, then adjust the needle, then ride, then jet it with a 70mm. and so on.
