IMHO, a forum section for that would be overkill. All that's needed is a few engine disassembly threads
Oh wait: there's already a bunch of those!![]()
Do say. How about you elabrate a little bit about how you replace your rod.
Then if it's not too much trouble, please explain what method you used to true the crank afterwards.
Really? When I think hub, I'm usually thinking wheels. Gearboxes, and sprockets don't really suggest crankshaft to me either.
How about,
Bottom end, Crankshafts, and Rods
Lets face it, this is one of the weakest areas in a china girl motor, and we don't have much information about them.
In this instance gearbox vs "bottom end" may be a minor matter of semantics as with most motorcycles, mopeds etc the gearbox is the bottom or lower end... granted the "china girl motor" doesn't have a transmission per say, but it does have reduction gearing, as does most of the small engines we use - thus "gearbox" is a general, all-inclusive term in common usage and covers many variants and components. While we could alter the title instead of a whole new subforum... it could make for a looooong title lol as "Hubs Gearboxes and Sprockets" is meant to be general, covering all aspects of power transmission, internal or external gears, multiple gears and/or just reduction, cranks, shafts, sprockets, etc.
The term "bottom (or lower) end" is also ofc in common usage, but it's usually very specific & excluding other topics which insofar as subforums are concerned, starts to lead down the path of having a separate subforum for each and every individual component, which needless to say gets to be problematic.
As not everyone has or is interested in one engine type alone, we try to strike a balance between such generalities and specific areas of interest, in fact every time a new subforum is discussed we find our memberbase is split between those that say we've too many as it is and those that say we've not enough - so in that we try to strike a compromise as well.
Certainly. If I'm going to bother, I'll unbolt the old one and bolt in a new one. Fiddle with it til it works. If it doesn't, replace it.
Of course. If I'm going to bother, I hammer til it works. If it doesn't, see above.
Therein lies the issue: many people consider the chinagirl to be a disposable toy engine. The Chinese seem to build em like so.
Alright I dig what you're saying. It's only a suggestion anyway, no big deal.
What about this idea, and then I'll shut up about it? Instead of starting a new forum, change the name of to
Crankcase, Gearboxes, and Shafts
Move the hubs to the wheels forum, since a hub is part of a wheel.
I agree most of the china girl motors are not much better than toys out of the box. I see new people lamenting that fact everyday. It doesn't have to be that way though. This forum is partly about lifting people up, so they can do what they need to do to make their bikes dependable...
