I installed a centrifugal clutch I mess up the key way that I tried to cut out so I took the key way out and just bolted it down and today the the regular clutch would not disengage for some reason is it slipping from the centrifugal clutch or is it the regular clutch acting up.When it would do it is when i went to start it and I would let the clutch lever out to start it and nothing then I kept pulling and letting go of the lever noting then I stood up to pedal fast and it would turn the motor over on it on then.So is that the centrifugal clutch slipping on the shaft or the regular clutch locking up?
