Thank you Bikeguy Joe for your response in the "solved whole chain tensioner thingy" Regarding my clutch problem, I removed the small metal rod in the center of the motor sprocket and cleaned out all the grease. The little ball bearing WAS in there, but it appears to be stuck. I was unable to get it out with a magnet or anything else I tried. I am confused by this because the rod and ball bearing fell right out on the floor before when the bike was accidentally tipped over. Also, no matter which way I move the clutch arm I don't feel anything.
About the tire...... If a 2.125 tire will rub on the chain, should I use a smaller tire and wheel on the back? Any help would be very appreciated.
