Hey guys, I just got my HS friction drive kit from 80cc Motorboys in Canada.
My problem is that the clutch disk thing wasn't threaded onto the friction shaft. When I tried to thread it on there, it won't fit. The threads will not even start.
(I used all 7 words repeatedly!)
I measured the shaft diameter, and it is 10mm OD. The threaded part inside of the clutch measures 9mm.
Should they be closer to the same size? I know there has to be room for the threads to interlock, but this thing won't even start to thread!
What would you suggest I try?
I sent an email to Ken at 80cc Motorboys to see what he says, but I think they're closed for the day.
I'm going to buy a metric tap & die set tomorrow on the way home from work. (I have one around here somewhere, but haven't used it in over 10 years, so now I can't find it when I need it!)
I'll run them over and inside the threads to check the size, and to clean the threads if needed.
Any other suggestions?
BTW, the good news is that the little 4 stroke fired right up! It's so quiet! I will be able to stealth ride with no problems now!
I just wanna ride!!!!!
![cvlt1 cvlt1 cvlt1](https://motorbicycling.com/images/smilies/cvlt1.gif)
![:-|| :-|| :-||](https://motorbicycling.com/images/smilies/Waa.gif)
