Hi guys. I've done two builds so far, both HT engines (mega motors 66cc from bikeberry). On the first, I had no trouble with the clutch adjustment. It's fairly consistent. It gets a little tight when it's been ridden for a while. However, it never needs adjustment. On my second build (pictured), the clutch is a bit problematic. When the bike is cold, I'll get it adjusted right. When the clutch is engaged, the bike cranks fine. With the clutch disengaged, the bike pedals fine with no drag from the clutch. After riding the bike for 30 minutes to 1 hour, and then leaving it parked for an equal amount of time, the clutch performs as though the flower nut had been loosened on it. In other words, the clutch no longer produces enough drag to roll start the motor. I have to open the clutch cover, tighten the flower nut one "notch", and then I can crank the motor. However, now, the clutch is so tight that it's hard to pedal the bike. After the bike sits for a while after the mentioned adjustment, it becomes so tight that I'm forced to loosen it a notch, only to later tighten it. It's an easy enough problem to fix, but it's just annoying to keep doing it over and over. Anyone know of a potential solution?
I appreciate the help very much.
