dlibs
Hello,
First I would like to say thank you for allowing me to join the forum and become a member of the community. Motor bikes have been a hobby of mine for some time and I’m excited to be here.
Now down to business:
I cannot for the life of me figure out what went wrong on my motor bike. It’s a typical 49cc 2-stroke Chinese motor on a 2010 diamondback Sorrento mountain bike. I installed the kit back in October and the bike has run fine since (except for eating 4 chains, but seeing as it already has 1,082 miles on it I guess that can be expected). I have done regular maintenance on it (cleaning the carb, cleaning the exhaust, oil on everything etc). I was riding it to a price chopper to run some errands when out of nowhere the bike started backfiring like crazy. I started losing speed and the engine started to die so I pulled in the clutch and the engine returned back to its normal idle. As soon as I let go of the clutch it started backfiring again and died. After that it would not start again whatsoever. I originally thought it was the spark plug so I replaced that and that didn’t fix it. I also replaced the cdi box because that had cracked due to cold weather. Now it pops and occasionally jolts when you try to start it but no go. I also noticed a fair amount of fuel is leaking out of the exhaust. Is it possible I blew a gasket? I have a spare carb lying around I might try putting on to see if that will fix it but if it’s an engine problem I won’t bother. My only reason for trying a different carb is that the fuel in the fuel line actually bubbles like a fish tank when you try to start it. I tinkered with the carb currently installed but no amount of screw configurations seem to result in any kind of improvement. I hope I don’t have to replace the motor because it is welded to my frame (that would suck). Any ideas, opinions, comments, or suggestions would be appreciated and are welcome.
Thanks,
-Dlibs
Thanks,
-Dlibs
