alienboy366
Do boost bottles really work? what's the idea behind this?
Pretty neat how boost bottles work but theres one problem, these engines don't have valves. Therefore it's a complete waste of money. I made one for my bike and the only thing I noticed was just about nothing.
Personally I use them, If I didn't make them myself I wouldn't spend the kind of money they want for them. Easy to make, and cost about $5.00.
1-1/2" Sch 40 PVC Sch 20 can be used but the bottle will be shorter.
Length is dependent on the cc engine size.
(2) PVC end caps
(1) 1/8" NPT brass nipple
(1) 1/4" NPT brass nipple
drill for both the 1/8 and 1/4
1/8 NPT tap
1/4 NPT tap
And believe it or not...JB Weld.
Should you decide to use one and want any assistance send a PM.
What is pictured is for a 66cc engine.
Ron
I recently got a boost bottle and installed it properly but when i fired up the engine after installing the bottle, the idle is way out of control. i have a CNS preformance carb i am using with this boost bottle. I cant even control the idle with the idle screw. it just dosent respond at all to the idle screw. It just idles super high, almost like i am pinning the throttle with the clutch in. I also played around with the air to fuel screw and i still couldnt adjust the idle or tune it at all. It did not do this before i installed the boost bottle. Any ideas on what the problem might be? I was thinking i need to get different jets for it.
The thread around the nipple most likely has a leak mine did the same thing. Pull the nipple out of the intake and reseal the threads on it that should fix you up.
