Well I've built my bike kit, made all the adjustments and my spedometer on my smart phone has 26 mph as top speed, I'm in the 20 mph club and I want to go faster. I'm content with the pick up but I want more top end speed. I'm more on the thick side if you catch my drift.
My big question is what can I do to increase my top end other than changing my sprocket to a 36 tooth one.
very catchy thread title! well, you prolly know theres a million threads on speed mods here. I've been reading my eyes out today, and have garnered some great new knowledge. I just watched a youtube video of a guy with a mountain bike style frame who had only done a couple simple mods, and not even jetted it. I'm not claiming these worked for me, but this is what he said:
1: abs plastic pipe ram-air setup on carb was a noticeable increase in power, (and this actually has piqued my curiosity. )"
2: he was using what looked like a 22 tooth sprocket! crazy! seems like a lotta pedaling before you see any power. pretty "no-torque" setup
3: he said he had gutted the exhaust. stock. not even an expansion chamber,
4: he had moved the needle up a notch to compensate for the ram air intake.
none of these sound like my gut instinct mods, but he claimed 45-53 mph. also looked to be about 17o lbs.
my setup bes
ts me 35 tops.
ocketbike expansion chaimber with 12 inch headpipe for torque
2: holes drilled in stock plastic air intake cover
3: 40 tooth sprocket
4: manic mechanic H.C. head
5: ngk bp6hs plug
6: 24:1 as I'm still breaking it in
7: needle at 3rd detent
8: im 6'3", 200lbs
9 ported intake manifold (helped smoothness)
ported exhaust manifold (not sure if it did anything)
I think I will try a 36 tooth just to see if that improves upon the 40t for top speed. she cruises comfy at 28 mph, then into the crazy shaky rev zone for the 30-35mph range. I'm thinking the pipe really has helped the engine run strong through the low & midrange, and the sprocket is the one thing thats holding it back on the top speed as far as things under the list of easy mods. My next steps would be opening up the transfer ports and widening the cylinder intake and exhaust, ports and perhaps triming the cylinder skirt , but that getting a little crazy. I think as few revs and rich as practical and you'll have a setup that wont cease on you. although after watching the video of the intended ceasure, I realized these things can take quite a beating. the guy ran WOT with no oil in mix for 3 minutes before it quit.
