7.4VDC 5W 1,000 Lumnes with 5 CREES $50.
KCvale
Got an old style bullet light with crap lamps in it?
This Retro Army themed Felt with a 4-stroke does and I am wiring up some REAL light for it.
This is the bullet light.
The diameter of the reflector is just under 3".
Now check out this flashlight which also has a reflector just under 3" wide.
And check this one out for $43![/size=4]
Specifications
Key Features LED flashlight, Flashlight torch
LEDs 5
Lumen Output 1000-1200 Lumens
Input Voltage 7.4V
Bulb Type 5 TR-800 CREE LEDs
Brand TrustFire
Power Supply 2 x 18650 3.7V Lithium AA sized batteries (not included)
Body Color Black
Light Color White
Weight 11.25 oz
Material T6061 aviation aluminum alloy
Working Temperature -25 ~ 65#8451;
Flashlight Life 10, 000 hours
Dimensions 8.27" x 2.24" (L x D)
7.2 volts is PERFECT for motorized bike uses, most motors put out over that, and 1,000 Lumens should do the trick, and the guys should drop right in the bullet ;-}
Want to go nuts? This will work for $100 ;-}
Specs:
Brightness 4300Lumens
Emitter Type CREE, XM - LT6
Light Color white
Bulb Quantity 5
Lighting Distance 900 m
LED Lifespan 10000 hours
Battery Configuration 3 x 18650 batteries
Input Voltage 11 - 14.4V
Power 20W
Switch Location Tail - cap
Switch Type Button
Modes 5
Mode Arrangement Hi > Mid > Lo > Strobe > SOS
Lens convex lens
Reflector Aluminum Smooth / SMO Reflector
Dimensions 11.81" x 2.95" x 1.10" / 30 x 7.5 x 2.8cm (L x Head Dia.x Body Dia.)
In short forget those $500 LED bicycle lights, you can REALLY light the road for cheap.
One other note...
Those Lithium Ion batteries aren't cheap and the retail price on them vary like crazy!
For example my local Batteries+ wanted $14 EACH for them, I bought a PAIR with the light for $6! Hence why my 1,000 Lumens light is only $50.
Cree's rule! I used two head lamp lights @ $15 each from the local hardware. The came with giant heat sinks and work while directly connected to my front wheel generator hub. They RIP.
Just a note, this outfit is in China so I imagine a couple of weeks for delivery, I don't have mine yet. I was looking at some other flashlights they have though, here is another one that caught my eye HERE.
Same 5 bulb design, just different cree's.
Specifications:
Key Features Flashlight
Brightness 900 Lumens
Emitter Type CREE Q5
Light Color white
Bulb Quantity 5
Lighting Distance 300m
Lightbulb / LED Lifespan 100000 hours
Battery Configuration 3 x 18650 battery
Input Voltage 10.8 - 14V
Power 10W
Switch Type Clicky / Clickie
Modes 5
Lens Coated Glass Lens
Dimensions 11.14" x 2.16" x 1.02" / 28.3 x 5.5 x 2.6 cm (L x Head Dia.x Body Dia.)
Material Aluminum
Weight 358g / 12.63oz
Package Includes
1 x UItraFiire WF - 1200 CREE Q5 10W 900LM 5 Mode Flashlight Black
And here's one for just $26.
Brand UItraFire
Model M9
Emitter Type CREE XM - T6
Brightness 950 Lumens
Power 8W
Bulb Quantity 1
Light Color White
LED Lifespan 100, 000 hours
Modes 5
Lighting Distance 250 m
Battery Configuration 1 x 18650 battery
Input Voltage 3.6 v - 4.2v
Runtime 3 - 4hours
Material Aluminum
Color Silver + Black
Dimensions 5.51" x 1.49" / (14 x 3.8) cm (L x Head Dia.)
Weight 142g / 5.01oz
Package Includes:
1 x UItraFire M6 CREE XM - T6 8W 950LM 5 Mode Flashlight Silver + Black
Note the head diameter is 1.49", too small to just drop in one of the old style bullet's.
Have this one on my bike and it light like a car with HID on it, Battery are Rechargeable and can be used as head lamp.
This is a $14 P7 1000 Lumen I dropped in the same type of light.I have a constant currebt regulator hooked up to it and it runs on the 7.4v RC batterry.I get about 4 hours with this and a taillight
Where did you get your light from? I really need some bright light when riding at night due to the fact that some street lights arent working and ive had some close calls.
All laptop batteries consist of 18650 li-ion 3.6v 2500-3000 mAhr. battery pack can be easily built for lights,
I use these under 60 buck and is't perfect small, various Voltage out puts and long lasting
http://www.ebay.com/itm/160649650437?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648
Charger 20.00
last for weeks only powering LEDs. 2 triple cree xm-l T6 head lamps I built. If the specs are right it should be about 5000 lumens. I would honestly never build these again as they are just way to bright for everyday city use. THey stay on low unless I'm showing'em off.
Re: 7.4VDC 5W 3,600 Lumnes with 3 CREES $50.
SUCCESS!​
I just finished my first custom retro bicycle headlight and it is just flat awesome for ~$60.
The retro bicycle light was nothing, it originally came with 2 flashlight bulbs and ran on a pair of AA batteries.
I pulled the reflector with 3 high power CREE LED's that pump out over 3,800 Lumes from this flashlight:
TrustFire CREE XM-L T6 5-Modes 3800LM LED Flashlight Electric Torch - Tmart.com
LEDs 3
Luminous Flux 3800 LM
5 Modes High-Mid-Low-Strobe-SOS
Light Color White
Body Color Black
Power Supply 2 x 18650 3.7V battery (not included)
Flashlight Life 100,000 hours
$49.
(continued next post)
...And fit it inside the original lamps reflector with a little fancy cutting and managed to wedge in a pair of 3.7V Li-Ion batteries to make this.
This is the old style bullet with new flashlight head in it.
This in the same position turned on.
It completely washed out my cameras ability to see any other light than the bulbs.
To emphasize just how bright it is, it's mid-morning, I have sunlight coming into my shop from a window and big sliding glass door, and that ceiling light has a pair of 100W incandescent bulbs in it.
Yes, that is the beam above and brighter than the ceiling lamps in a lit room from 15' away. It even washes out the softer yellowish light on the ceiling on the way there!
Not bad for ~$60 including the Li-Ion batteries ehhh ;-}
Here is how the light turned out on the bike.
Note I pushed the front bag in so you can see better.
These little 18650 3A lit batteries are pretty cool.
Did you know each one has a circuit built into the minus end?
1_LithiumCellInside.jpg.FP
They also like to be charged individually.
With RC and laptop battery packs they obviously can be charged in series, from what I read they have to do some tricks like charge, then drain some, charge again, etc.
For this Army Felts light I just ran a wire out of the light to a plastic battery clip that stows in the front bag.
Also in the bag is the little dual cell wall charger and a fresh set of batteries.
It's a breeze to swap batteries and with the little charger you can charge the other set away from the bike anywhere you have an outlet.
I beleve thats a "protection" circut on the end to stop runaway dischage in the event of a short hopefuly to keep the bat from overheating and blowin up... Nice job on the light and battery set up! And NICE FELT ! Did you do the camo or did it come to you like that?
No I didn't paint it, in fact this bike had a long history before it even got to me.
http://kcsbikes.com/topic.asp?TOPIC_ID=329
In short this guy had been trying for a year and half through 3 different builders to make it go before it came to me.
The initial problem was easy to see, the rear sprocket was mounted inside the outside of those 2 1/4" tires and no straight path to the motor sprocket and the other guys just tried to force the chain to go around.
Anyway, once I finally got the back wheel rebuilt, motor mount set and such other things came up like the front drum and such so I pretty much just rebuilt the thing and awaiting pickup, I just didn't paint it ;-}
