Deposited June 21, 2002
Motor Vehicle Act
Motor Assisted Cycle Regulation
Contents
Motor
1 (1) A motor assisted cycle must have no more than one motor for propulsion.
(2) The motor of a motor assisted cycle must
(a) be an electric motor,
(b) have a continuous power output rating of not more than 500 watts, and
not be capable of propelling the motor assisted cycle at a speed greater than 32 km/hr on level ground.
Wheels
2 (1) The wheels of a motor assisted cycle must be 350 mm or more in diameter.
(2) A motor assisted cycle must not have more than 3 wheels in contact with the ground.
Motor shut-off requirement
3 (1) A motor assisted cycle must be equipped with a mechanism, separate from the accelerator controller, that
(a) allows the driver to turn the motor on and off from a normal seated position while operating the motor assisted cycle, or
(b) prevents the motor from turning on or engaging before the motor assisted cycle attains a speed of 3 km/hr.
(2) The motor of a motor assisted cycle must turn off or disengage if
(a) the operator stops pedaling,
(b) an accelerator controller is released, or
a brake is applied.
Generators
4 A motor assisted cycle must not be equipped with a generator, alternator or similar device powered by a combustion engine.
Brake performance requirement
5 (1) A motor assisted cycle must be equipped with brakes on all wheels or on each axle.
(2) The braking system must be capable of bringing the motor assisted cycle, while being operated at a speed of 30 km/hr, to a full stop within 9 m from the point at which the brakes were applied.
Drive system and equipment securement
6 The motor drive system and all energy storage devices of a motor assisted cycle must be secured to prevent movement in any direction relative to the motor assisted cycle while the motor assisted cycle is operating.
Electrical terminals
7 All electrical terminals on a motor assisted cycle must be completely insulated or covered.
[Provisions of the Motor Vehicle Act, R.S.B.C. 1996, c. 318, relevant to the enactment of this regulation: section 182.1]
Hello orge power my dad keeps showing me this^^^^ whenever i bring up the argument hes reading this off the icbc page but maybe i should take him to the rcmp station and see what they say?also please tell me that the above doesnt apply to my bike thanks again orge power you have been a huge help-keith
