Simple question: What are some recommended specific bicycles that this engine will fit in and work well with?
Thanks
beaver rat
you do know that this motor with clutch will be a little over a foot wide.
there are NO install kits made for it either means you have to make your own throttle linkage and cable. plus motormount. Unless you use a CVT setup you will need a jackshaft and also a way to mount the rear sprocket to your hub. You spend more on the parts then you will spend on the motor
these are the only guys that make parts for the 99/79cc motors
https://www.affordablegokarts.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=MTRBK79
Yes, I do fully understand all of those aspects. Im fact, I have already made a cable throttle adapter system for the engine which works perfectly. All I'm doing now is looking for a good bike to put this system on. I know that many of the cruiser bikes will fit this engine, I was just wondering if anyone knew of any large triangle mountain bikes that would fit it.
Thanks
