wayne z,
The 3L belt slips easily, the AX belt doesn't slip at all.
I'm sticking with the larger AX belt, but thanks for the input.
I'm always trying to invent a better mousetrap...lol
-Lowracer-
I noticed on the Grainger PDF that you mentioned post #20 on page 2 of this thread, it says that the AX notched v-belts "not for use on clutching applications because of aggressive grip".
I suspect you have a centrifugal clutch on these engines and the AX notched worked out fine despite what they say, yes?
http://www.grainger.com/tps/power_t...e.pdf?cm_sp=TPS-_-VBelt Reference Guide-_-Top
I've already bought two of the Silmilar Gates TriPower AX belts and one of the Dayton Premium AX belt for my three belt system. I have two jack shaft system for a total 40:1 reduction.
I have the Gates A v-belt  Powerated brand and am thinking to try AX belts with the notches so I will try to get better grip especially on the smallest pulley about 2" diameter.  It can slip when on very steep hills or just accelerating out.
One thing I also heard was for slippage besides using belt dressing (liquid spray), the use of talcum powder can prevent slippage. I don't know if that is something like the old locomotives that used steam and I think some fine grit that sprayed under the powered wheels. (found this:
http://science.howstuffworks.com/transport/engines-equipment/diesel-locomotive3.htm ) They used sand, probably not good for belts, but fine talc sounds like an idea.
I saw the use of Talc idea on the thread:
http://motorbicycling.com/showthread.php?t=42121
Page #1 post #9 Tooljunkie wrote on your other thread "Dax Friction drive converted to V belt drive"
I might try this first before using the belt dressing liquid spray if I find the need on either the A or AX v-belts I have. The pure talc I got already is from
Tap Plastics and does not have asbestos or alcohol in it, so is safe for people and the belt itself.
MT
PS the way you made the sheave and attached it I admire! Does it use any fasteners beside the strong glue?
http://motorbicycling.com/showthread.php?t=29678&page=13 Page #13 Post #129 The Trail Bike Mode - OHV CA DMV approved
http://motorbicycling.com/showthread.php?t=29678&page=14 Page #14 Post #133 to Post 137 for my searching and attaining the notched AX Belts
