I'm just curious.
I did the pull start test and saw sparks yes.
But my father said it should spark while turning the flywheel by hand so I wanted to know if you had the same results as me. Maybe not for these engines should it spark by turning it by hand?
My multi meter readings were in Ohms in 3 different spots and readings were consistent:
0.4
1.6
2.0
And I wanted to make sure I had a good Coil by asking you if you had the same results. That way I can be sure those are the correct readings.
hi !
i have had "AL" marked/manufacturer Ht-coil/cdi Combo that failed in 15mins from new. it had never run in a wet conditions or soaked in water or simular. it was the poor quality1 without the silicone on the Ht-cable fittment (These dont like water or moisture that gets in as there is no silicone..BUT i think the part Quality is also bad.
now i have a lot better quality silicon sealed "XG" marked/manufacturer Ht-coil/Cdi combo that has done so far 850km. i still have the original bad chinese Ht-cable on it but with champion Plug.
i dont know how many Rev's does Cag need to Produce sparg BUT i would expect at least 500rpm (as most 2T mopeds etc need 500~850 rpm or so to Produce sparg). 2t's are not like OLD non-cdi 4T Briggs&Strattons that can be hand wiggled to produce sparg (youtube vid...)
Thx for those Multimeter results and photos, etc photos that you have posted here at this topic of yours.
im intrested to hear what markings do you have on your Ht-Coil/Cdi combo.
btw. i have my Cag engine running backwards, ive "mirrored my Ignition", to suit my Application..
http://motorbicycling.com/f36/front-mounted-minimoto-engine-16978-4.html
ive done ridden so far 850km with it. about 750km from it with 1 single same Race Clutch which is still like new..
Std 3-shoe Spring snapping problem that i had:
http://motorbicycling.com/f4/pocket-bike-engine-project-31377-10.html
what comes to the BBK cylinder assy, i think i have same or very simular as yours (not in use yet) Mine:
http://s721.photobucket.com/albums/... ja purkuosat-/?action=view¤t=kitti.jpg
with the short Vertical Groove above exhaust port hole at middle. ive had 3 of these kits going through my hands inspections b4 re-shipping, 1 i bought for my own use.
i have 1 of those Reduction GearBoxes also that you have, cant remember mine Brand atm (ill check) . Mine is cannibalized1 without the internal chain. its 1 row chain and my Box has internal ratio 3,22. bought it from fleamarket for approx 3usd.
im intrested to hear your future experience with it with Gearings that you might go through or have in use if not experimenting various settings.
bye
m
