So what oil are you using? Also where do you get 2 stroke oil, do auto parts stores carry it? Right now I am using chainsaw 2 stroke because it was given to me for free. What should I change to?I run oil that has the highest flash point, provides a dry lubricant when the engine overheats, and has superior lubrication under severe conditions. I've run it at 50:1 but prefer 32:1 as an easy mixture ratio.
I have only used Amsoil oils.
Justin I do not see why you switched to Yamalube 2r other than the cost, but IMO Amsoil is the founder of synthetic oils so they make the best synthetic oils. There is a reason why they don't sell them at retail stores.
With Amsoil I have only heard good results and haven't heard any one experiencing carbon build up. With Castrol oil some experienced some carbon build up in their engines, but it worked just fine.
Baker's Grade AA Castor Oil - SIG Mfg. Co., Inc.
I've had no issues with gunk buildup running 100% castor oil but you wish, you can blend it 3oz of cheap 2 stroke oil (walmart stuff ok) with 1 oz of castor oil for total of 4oz per gallon.
Pablo what about pure synthetic using just Amsoil Dominator?
Nothing wrong with it. No matter what after all these years, castor oil still makes the best ring seal and extreme protection. Mixed with synthetic oil to keep it clean, it is an awesome combo.
