I been reading around and trying to get my NT carb tuned properly. What it's doing is bogging down at 3/4 to full throttle. It runs and idles fine, but whether I'm riding or siting still, if I try to rev the rpms up to full throttle it bogs and it's not getting to full rpms. I had a cns2 carb on it that I could never get fuly working.(I didn't try to drill the jets, I just got the bits in today.) This CNS carb, when I closed the clock would kick it in gear and it would then jump forward at full rpms. So I know what the motor is capable of. With this NT carb, if I try closing the choke it bogs it down and kills the engine. So the only thing the choke is good for with this carb is for cold starting. Which is what it is suppose to be for, really. I can't really tell but I think it might be 4 choking when it gets up to high rpms.
I found this site that has a great guide on the nt carb. NT Carb Tuning Basics - MotoredBikes.com: Motorized Bicycle Forum
Here is a video of me showing you how the rpms fluctuate when at full throttle while riding and sitting still. I know when I had the CNS carb on and was sitting still, it would rev up all the way and I would stop afraid of blowing something up it screamed so high. Now, I run at full throttle and can hold it there with no worries. I know it has lots more power to give.
Oct11_0001.3gp - YouTube
Heres what I've done so far.
1. I've check the the distance from the carb bottom(where the gasket goes) to the top of the float is 21mm. And it was.
2. I've sprayed starter fluid where the carb connects to the intake, to check for air leak. It didn't rev up but it did rev down. But this may be because some got pulled into the air filter.
3. The C-clip was originally set on the second from the top. After reading the above link, I realized the slide needle also controls the idle in a way. Well in the second notch my bike wouldn't idle even with the screw turned all the way in. I move the c-clip down one notch at a time until I realized moving it down was only making it worse. So I moved it to the very top notch and that is where it is at now. I am able to adjust the idle now with just the screw.
I was worried that I might run too lean with the c-clip all the way on the top notch. Well I have no spare plugs to test at the moment. (have 4 on order) But I have been riding it to work and back the last week. (only a half mile, round trip) I took the plug( Plug is a few months old) out today and the spark area is nice and dry but the rest of the plug is black and oily wet. I tried taking some pics but my phone would not capture a good res pic that close
Here is my blurry pics:
http://img94.imageshack.us/img94/664/oct110004.jpg
http://img822.imageshack.us/img822/9895/oct110005.jpg
http://img43.imageshack.us/img43/4852/oct110007.jpg
can only add 5 imgs, so I just posted a link to last 3
I did find a good quality pic on the net that I think looks close. Not so black on the spark tips
So where I'm at is I figure I needed to drill out my jets. Because in the above link it says the jets control the 3/4 to full throttle part. I think I need to go bigger, but I'm not sure and before I do anything I wanted to gets some advice on if I'm doing things right.
I bought the micro drill set on amazon. Here is the link; Amazon.com: 20pc MICRO-DRILL BITS INDEX 61-80 w/ Plastic Case: Home Improvement Everyone I read talks about sizes starting from like 70 to 76, or something like that. But the sizes on this set are from smallest to largest; 0.3, 0.35, 0.4, 0.45, 0.5, 0.55, 0.6, 0.65, 0.7, 0.75, 0.8, 0.85, 0.9, 0.95, 1.0, 1.2, 1.3,1.4, 1.5,and 1.6. I tried looking at this conversion table I found, but I can't figure it out. Drill Size Conversion Table
Anyways, I'm not totally 100% I should even drill out my jets to a larger or smaller size. But it seems that everyone that has problems with theses carbs, that is what they end up doing.
What do you guys think? Thanks and if you you need any more info just let me know?
Btw this is my new bike from my crashed one. A thread I started a few weeks ago.
![.wee. .wee. .wee.](https://motorbicycling.com/images/smilies/wee.gif)
Here's my crash thread
![](/proxy.php?image=http%3A%2F%2Fimg580.imageshack.us%2Fimg580%2F9943%2Foct110003.jpg&hash=35e1167242083a013476be8419ba100e)
![](/proxy.php?image=http%3A%2F%2Fmotocrosshideout.com%2Fwp-content%2Fuploads%2F2011%2F02%2FWhy-Does-My-Dirt-Bike-Keep-Fouling-Spark-Plugs.jpg&hash=329177bc658d11dc4bad93ba2d896d47)
![](/proxy.php?image=http%3A%2F%2Fimg854.imageshack.us%2Fimg854%2F8279%2Foct110001.jpg&hash=c659b9af9b2d6e9caf2bdcc680de032d)
![](/proxy.php?image=http%3A%2F%2Fimg31.imageshack.us%2Fimg31%2F605%2Foct110002.jpg&hash=041c1baa8441259f8a938dfe370f7df1)
