You and me both because I have yet to see anyone attempt it yet. So I'll be on my own on this on. Who want's to be the first one to ride in the sidecar? I better learn how to weld and weld good. LOLI'll believe it when I see it
Actually I'm going to bolt a standard go kart frame to the side of the Felt MP and remove all the wheels, steering wheel and front assembly from the go kart and attach a single bike wheel to the rear outside of the go kart. The go kart already has all the drive train, hardware and mounts for the engine plus a seat for the side car.I'll believe it when I see it
Faith in engineering? What engineering example of what I'm trying to do are you referring to exactly? LOL Enlighten me please. I've got Google to.lol dude, it's an anecdote from my childhood....I don't care if you believe me. but show a little faith in engineering...
flying motorcycle
I'm not trying to build a U.F.O., just a glorified premade side mounted pusher cart is all.I'll believe it when I see it
I'm in Los Angeles. Where you already have one foot in grave when you get on a regular pedal powered bike, let alone one with an engine and sidecar attached to it. At least I can power out of the way from being ran over by someone in a SUV, texting on their cell phone, with an engine attached. LOLWhen I was a kid there was a legless biker dude in town who built something sort of like this, but it was obviously a motorcycle & the engine was in the usual place. The cool part was that he could drive & steer from the sidecar & a passenger could ride on the bike seat.
Didn't see too many passengers on that thing....
I'm going to try my best to drive both rear wheels with one extra wide go kart axle running straight through both rear wheels (bike and sidecar) but who knows how hard that is gonna be. The bike will remain untouched with all the power, drive-train, and go kart disc brakes hidden behind the sidecar seat which is a standard go kart seat. The sidecar will be built to hold a 6 foot tall person in it and the engine will be a minimum of 200cc 6.5hp 4 stroke Stage 1 Go Kart engine with a Comet Torq-A-Verter on it. When I hit a hill it will not matter. It will just keep accelerating.Sounds like a fun project!
Other than the normal issues w/any sidecars (handling & maneuverability, width) the only issue I can think of is applied traction (minor), while there may be some "torque steer" (wrong word methinks, but I can't think of one better either lolz) from the offset drive wheel, I think it'd be minor & easily compensated for *shrug*
A couple few of our members have gone the sidecar route (tho none powered as far as I know) http://motorbicycling.com/members/fasteddy/ & http://motorbicycling.com/members/silverbear/ come to mind... Might wanna check this thread fer inspirations ifn you've not seen it already: http://motorbicycling.com/f38/sidecar-12559.html
I'm surprised no one has tried to make a side car out of a modified go kart frame with the engine inside the sidecar where it normally sits in the rear of a go kart and then attach it to a bike. Maybe I'm just crazy but I don't see why it can't be done. I guess I should keep a bottle of aspirin close by when I start building this thing.Sounds like a fun project!
A couple few of our members have gone the sidecar route (tho none powered as far as I know) http://motorbicycling.com/members/fasteddy/ & http://motorbicycling.com/members/silverbear/ come to mind... Might wanna check this thread fer inspirations ifn you've not seen it already: Sidecars?
I think a long long wheelbase on the bike is critical. There are all kinds of old cars that have rear 1 wheel drive so it has to be possible. If my go kart /sidecar idea works then it will be a major coup because the go kart is pre-ready for everything. If not then I can finally rule that idea out for good. LOLFasteddy here. I did that with an electric wheel on a sidecar and redid it with a powered back wheel after riding it a block.
The wheel on the sidecar had a tendency to turn into the bike since the bike was slower than the wheel on the sidecar which used the bike on take off as a pivot point. Kind of like standing on one foot and running with the other. You just turn in a circle.
It would work I think if you were willing to pedal the bike to get it moving at a decent rate of speed and the release the clutch or put power to the wheel.
I can't imagine what turning your bike would be like but mine was a nightmare. The tire scrubbed and the wheel shuddered until it was straight while doing a left turn. Right turns may be impossible since you are turning into a wheel trying to go straight ahead.
Worth a try to see if it works for you but I won't do it again.
Steve..
This ain't going on no circle track. This is going to be daily transport through the streets of Los Angeles. LOL The go kart axel will have a drum or disc brake on the drive axle like a regular go kart does.Don't forget, those old cars have 2 wheels steering in the front.
I was just thinking about how you drive a traditional sidecar rig, and I believe you need to accelerate on right turns, because the bike travels further than the sidecar. On your proposed rig, accelerating would make things worse on a right turn. You would have to cut the throttle on right turns, which might not be enough. Your rig may require a brake on the right wheel.
It should make lefts like nobody's business. Maybe use it for circle track?
I initially wanted to put a 200cc Stage 1 Go Kart engine on a Felt MP but that engine is way too wide to mount on any bike and looks kinda goofy so I came up with the sidecar idea, but after further searching, I finally found a fully automatic, 125cc, 4 Stroke, w/electric start, Piranha pitbike engine that will easily mount on a bike without my legs being bowed out like I'm on a Harley. Go Kart engines just don't look or fit right on a bike. I want a 4 stroke engine that looks like a traditional motorcycle engine and is narrow. The sidecar idea I think is just gonna be too much trouble for me to handle at this point, although the fun factor would have been high.Don't forget, those old cars have 2 wheels steering in the front.
