Seems you are using this crank: 3pc Wide Crank Pedal Kit [4S-CDS-3pcCRANK] - $29.99 do I need anything else to switch over to this new wide crank as I seen no bearings with this kit and as you know this bike comes with a one pc crank so do I need anything to mod this bike to take the 3 pc crank set? I couldnt wait to buy the forks so I bought these: SR Suntour XCM 26" Black 1" Threadless does anyone have any input on these forks? Thanks for thelp guys!
Well Ive been trying to order your part number AGK700 and it seems to be back ordered? Is there any other header that would fit this bike / motor combo?
I forgot to mention the suspension fork we use. We get it in either 1" threaded or 1" threadless. It accepts a hydraulic disc brake or v-brake. We use a hydraulic disc brake with a 160mm rotor. I'll try to post some pictures of it tomorrow.
Can you post a link to the 1" threaded type. My bikes forks have threads so I had to send back the ones Ive been waiting for, for 2 weeks. Running out of time in this house as I must be out by the end of the month so any help would be a life saver. Thanks.
We have an account with a bicycle parts supplier which is where we get the forks. I can get a set of the threaded forks for you if you want.
If you still have the threadless forks you may want to consider converting to threadless. You will need a 1" threadless headset and a 1" stem. Your local bike shop should be able to help you with those parts. The threadless system looks much cleaner, it's a little easier to put together and it's probably stronger.
If you already sent your forks back and want my help getting a threaded set, just give me a call.
Hey Old-timer...I had the same issue and a couple friends I had over found the problem. The throttle cable was a little too short which was keeping the slide open on the carb; we ended up cutting some of the cable housing off which made the cable longer. We used a dremel tool to carefully complete this. I have also posted a picture to show you the screw for the idle adjustment.
About the motor heating up: do you have the shroud on this motor or does it look like the one in the picture? All I can say is it gets hot real fast of not moving with air over it.
I would also order some more jets or read the post on the AGK site about jetting the carb. Its cheaper to drill them out then to buy a bunch.
If you can post some pictures it would also help.
Let me know if you need to chat...
CCC
If your exhaust is glowing red you are definitely running that engine lean. Check your spark plug, it will be white. No surprise with the stock main jet, but difficult for me to give you a good recommendation due to your high elevation. Your Mikuni probably has about a #95 main jet from the factory. We usually run about a #125 main jet with your engine combination at sea level. So you may want to try about a #105 main jet. Like CCC said it's cheaper to drill jets.
If you are getting a lot of vibration on the initial clutch engagement you can run a lower gear ratio to help clear that up. Just go to a larger rear sprocket. These engines are not very well balanced so they do vibrate more than expected. Bryan told me he can hardly hold the handlebars at the end of a straight when the engine is turning 8500 rpm due to the vibration. When the balance shop balances the engines they say the engines are pretty far out of balance. They charge about $150 to balance the rotating assembly.
I might be getting a little carried away here. Let me know if there is anything I can help you with.
ok Iam lost 95 jet 105 jet 125 jet? Should I drill out my jet to give it a bigger hole or should I solder my jet and make the hole smaller?
AGK,
With vibration being an issue would you recommend just going ahead and balancing the engine? Who do you use for this service? Jeff, how is the vibration on your engine? Problem? I would guess some engines stock are balanced better than others. I hate vibration on bikes.
