Hi guys, im trying to build a Trek road bike with a 80cc boygofast engine from ebay. Ive got it in there, and can start it with an air ratchet on the magneto bolt, but i just cant get it running at all with pedal power. Im wondering if its partly a clutch not engaging hard enough problem? I can have somebody hold the bike down with clutch engaged, and it turns the motor with an air wratchet on the magneto while the clutch slips and the back wheel stays stationary, should it be holding tighter on the clutch?
Seems like if i installed the pullstart that he sells, id have a chance of the bike firing up if it died on the road, right now i can only get it going with air power on magneto bolt. It has good compression, checked that, 120 lbs. I think the magneto is flakey though, white wire is reading dead short to ground, I ordered a new one, so i took the old one and cut some windings on the inner white wire coil, so if its still shorting out, it wouldnt be as bad. Im hoping hotter spark will help when the magneto comes this next week.
Anything else i should try? Im wondering if a bike with 27" tires can get the motor spinning fast enough on flat ground to start? It seems geared really high on these big ol tires.
Looking for moral support here
