hong@hong kong
If you mean centrifugal clutch like this:
Yes, I am using one, and all future builds will have one.
I enjoy it very much, and will never go back to manual clutch again.
How does it work?
Does it need to work with the pull start?If you use the centrifugal clutch don't you have to have a pull start?
At idle the inner weights turn, but the outer bell that is connected to the rest of the drivetrain does not. When you rev the engine, the weights fly out (due to centrifugal force) and grip the bell and everything turns together. When you slow down the weights retract and the grip is lost and it freewheels.How does it work?
I think you had just used the Google Translate.
Do you know what "卑微" means?
Do I need the clutch if I have the pull start?
This Chinese kit is the latest version with the 85cc engine.
9.8hp@14000rpm
40 tooth 5 holes sprocket
2.5L fuel tank
I only cost me about 110USD(850HKD)
I mean if I have the pull start and the centrifugal clutch,do I need the manual clutch?
