DuctTapedGoat
The e-clip is the clip on the throttle needle inside the slide barrel in the carb.
WOT is Wide-Open-Throttle.
Sorry, the e-clip is on the needle that controls fuel flow as you twist the throttle, raising the clip will lean the mixture lowering the clip will richen it. wot stand for wide open throttle.
I just ride to be honest, just no long trips until I feel things loosen up.
From what I've heard, to get everything to set you want two things.
1. Fluctuating/variating throttle.
2. High load.
So when I was setting my new rings I climbed a series of 3 hills with downhills between. Elevation increase of roughly 700ft, then idled down giving it small revs. I'm still setting them, and I plan to do it again later today.
